I have 3 315MHz RF Ceiling fans in my house. I have setup a receiver and transmitter with OpenMQTTGateway which is working wonderfully after failing to get ESPHome working.
I am attempting to setup the fans in my configuration based on the codes I sniffed from the remotes. The remote has 4 buttons: Off, Speed 1, Speed 2, and Speed 3. Each button sends a different code. The off payload looks as follows:
"value": 522775,
"protocol": 6,
"length": 24,
"delay": 482
I tried to setup the fan using the template examples I’ve found and have fooled around with getting the fan state/speed state to stay in sync with the remote/HA. I think I am just misunderstanding how OpenMQTTGateway and Home Assitant interact. I have posted the config that I am trying to use and hope someone can set me straight. Thank you.
fan:
- platform: mqtt
unique_id: fan.office_ceiling_fan
state_topic: "home/OpenMQTTGateway/433toMQTT"
state_value_template: >-
{% if value_json.value == 522887 %}
{{'ON'}}
{% elif value_json.value == 522823 %}
{{'ON'}}
{% elif value_json.value == 522951 %}
{{'ON'}}
{% elif value_json.value == 522775 %}
{{'OFF'}}
{% else %}
{{ states('fan.office_ceiling_fan') | upper }}
{% endif %}
speed_state_topic: "home/OpenMQTTGateway/433toMQTT"
speed_command_topic: "home/OpenMQTTGateway/commands/MQTTto433"
speed_value_template: >-
{{'low'}}
{{'medium'}}
{{'high'}}
{{'off'}}
{% else %}
{{ state_attr('fan.office_ceiling_fan', 'speed') | upper }}
{% endif %}
payload_off: '{"value":522775,"protocol":6,"length":24,"delay":481}'
payload_low_speed: '{"value":522887,"protocol":6,"length":24,"delay":481}'
payload_medium_speed: '{"value":522823,"protocol":6,"length":24,"delay":481}'
payload_high_speed: '{"value":522951,"protocol":6,"length":24,"delay":481}'
speeds:
- 'off'
- low
- medium
- high
availability_topic: "home/OpenMQTTGateway/LWT"
payload_available: "online"
payload_not_available: "offline"
qos: 0
With this setup I am able to control the fan with the remote or HA, but HA doesn’t see speed/state changes done with the remote. Can someone point me in the right direction? Thanks.
