Protocol: Generic temperature sensor 1
Hi i read wrong temperature and battery values from a cheap and old externale temperature sensor.
The sensor is identified as Generic temperature sensor 1. For example when the display show 27,3° the sensor reported value in decoded signal is 114.4. Is there a way to read the raw values transmitted from the sensor on 433mhz? Or force another protocol what decode correctly the signal?
