Hi all.
I own both an M5StickC and an M5Atom lite boards. Both devices crash after a random amount of time between a few seconds and some minutes.
I tried to decode exception on M5Atom lite and this is the result:
abort() was called at PC 0x401f4c5f on core 1
Backtrace: 0x40092598:0x3ffd05f0 0x400927c9:0x3ffd0610 0x401f4c5f:0x3ffd0630 0x401f4ca6:0x3ffd0650 0x401dd083:0x3ffd0670 0x401dd2c2:0x3ffd0690 0x401dd261:0x3ffd06b0 0x401f71b1:0x3ffd06d0 0x400fd37c:0x3ffd0710 0x400dbc32:0x3ffd0730 0x401005d5:0x3ffd0750 0x4008ece1:0x3ffd0770
#0 0x40092598:0x3ffd05f0 in invoke_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/panic.c:707
#1 0x400927c9:0x3ffd0610 in abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/panic.c:707
#2 0x401f4c5f:0x3ffd0630 in __cxxabiv1::__terminate(void ()()) at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc+±v3/libsupc++/eh_terminate.cc:112
#3 0x401f4ca6:0x3ffd0650 in std::terminate() at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc+±v3/libsupc++/eh_terminate.cc:112
#4 0x401dd083:0x3ffd0670 in __cxa_throw at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc+±v3/libsupc++/eh_throw.cc:87
#5 0x401dd2c2:0x3ffd0690 in operator new(unsigned int) at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc+±v3/libsupc++/new_op.cc:54
#6 0x401dd261:0x3ffd06b0 in operator new[](unsigned int) at /builds/idf/crosstool-NG/.build/src/gcc-5.2.0/libstdc+±v3/libsupc++/new_opv.cc:32
#7 0x401f71b1:0x3ffd06d0 in WiFiUDP::parsePacket() at /home/christian/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiUdp.cpp:129
#8 0x400fd37c:0x3ffd0710 in ArduinoOTAClass::handle() at /home/christian/.platformio/packages/framework-arduinoespressif32/libraries/ArduinoOTA/src/ArduinoOTA.cpp:367
#9 0x400dbc32:0x3ffd0730 in loop() at main/main.ino:1110
#10 0x401005d5:0x3ffd0750 in loopTask(void) at /home/christian/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:19
#11 0x4008ece1:0x3ffd0770 in vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c:355 (discriminator 1)
Rebooting…
Unfortunately I’m not able to understand what’s the problem, so I would appreciate if someone can help.
Thanks for reading my post.
Regards.
Christian
