I’m want to use OpenMqttGateway to use as a ir extender With optional mqtt functions.
I’ve seen soms options in the config_IR.h file.
What does the RawDirectForward do. Is it retransmitting the signal from the reciver pin to the emitter pin ?
And i have a lot of unknow devices
So i have pubIRunknownPrtcl true also enabled.
Is this working with RawDirectForward ?
Thanx a lot,
Jan-Willem
