Recommended config for using esp32 gpio <-> mqtt?
I like to ask what is the recommended configuration if I just want to use gpio pins as inputs. Typically connected to dry contacts, like magnetic door contacts, in the esp32 and send status changes via mqtt?
What to select/enable in
  • platformio.ini (is default_envs = esp32dev-all correct ?)
  • User_config.h (is #define ZsensorGPIOInput “GPIOInput” //ESP8266, Arduino, ESP32 correct ?)
Kind regards, Walter
Yes you can use esp32dev-all and remove all the zgateways and zsensor except ZsensorGPIOInput.
You don’t need to modify user_config.h unless you want to apply special parameters.
Thank you very much!
I managed to partly make it work, I have no problems setting output pins on/off but instead of the recommended command ‘{“pin”:15,“cmd”:0}’ I actually have to use ‘{“pin”:15,“state”:0}’
EDIT: seems I used an old version, after project update I now use “cmd”
For inputs I have no success so far so I must be missing something in the project configuration I suspect. Only thing I can see is incoming mqtt messages like “{“adc”:64}”, “{“adc”:0}” etc
  • what gpio pin is used for adc? I have no input named A0 on my esp32
So still to solve is to make the gpio inputs reacting when changing from high/low and vice versa and status changes being reported via mqtt. When I try I do not see anything in the serial monitor either
Question is if I have missed something???
User_config.h
/-------------DEFINE THE MODULES YOU WANT BELOW----------------/
#define ZactuatorONOFF “ONOFF” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
#define ZsensorADC “ADC” //ESP8266, Arduino, ESP32
platformio.ini
[env:esp32dev-all]
board = esp32dev
‘-DZactuatorONOFF=“ONOFF”’
‘-DZsensorADC=“ADC”’
‘-DZsensorGPIOInput=“GPIOInput”’
‘-DGateway_Name=“OpenMQTTGateway_ESP32_ALL”’
Could indicate your esp32 model please ?
You can check in config_ONOFF.h that the pin used correspond to the one you are using.
You can also specify it directly into platformio.ini.
Thank you,
This is the esp32 model I have (see picture)
So what gpio pin do you think is used for adc?
(EDIT: I found out, it is the Sensor VN (GPIO39), next to D34)
It was actually in the config_GPIOinput.h I had to change, so now it is working fine with the input I use
Just thinking, in this code part, would it be possible to add support for several input pins? Right now it can only support one single pin?
/*-------------------PIN DEFINITIONS----------------------*/
#ifndef GPIOInput_PIN
  #if defined(ESP8266) || defined(ESP32)
    #define GPIOInput_PIN 14
  #else
    #define GPIOInput_PIN 7
  #endif
#endif
Great if you found it out!
I would like to do the same thing. Do you have complete instructions somewhere that explain how you got this working? I simply want MQTT messages when state changes on a few IO pines.
Nevermind, I seem to have this working. I am going to try to make a detailed write-up to make it easier for the next person.
I also would like to monitor more than one GPIO pin. Is there a way to do that?
