I made Milan’s 360 setup and it works great. It has a very good range.
Now, I noticed something strange looking trough my phone camera. LED’s are lit all the time. They are very dimmed, but on.
When I publish MQTT command, it works normally. Lokking through cammera, all LED’s flash brighter, and go back to constantly on.
Anyone else expiriencing this? Is this normal behavior?
At first I thought my transistor was blown, and I replaced it, but i get same thing… Then I thought, if it is blown it wouldn’t send the signal, right?. I’m not so good with electronics obviously
Did you try to remove transistor and check if LEDs light? Also, did you try setup with different resistor (replace 1K with 150ohm).
It is not normal that LED light all time (in my configuration)
