Hi! I installed the binary release v0.9.5.nodemcuv2-rf2-firmware.bin to my NodeMCUv2 with the cheap chinese 433MHz set “F1000A” attached. I want to send on/off commands to some 230V-plug-switches using the kaku protocol. Before, I successfully sent these commands using pilight on a raspberry pi with the same F1000A sender, with the following config:
"devices": {
"A1": {
"protocol": [ "kaku_switch_old" ],
"id": [{
"id": 0,
"unit": 0
"state": "off"
"hardware": {
"RF433": {
"mingaplen": 4420,
"maxgaplen": 72900,
"minrawlen": 26,
"maxrawlen": 400
where the addresses A1,A2,A3,B1,… correspond to pilight unit/id combinations 0/0, 0/1, 0/2, 1/0,…
Now my problem is I cannot get openmqttgateway to decode anything (trying with the remote that was packed with the power plugs, right next to the antenna), I suppose the F1000A receiver is too bad.
I don’t actually need the receiver, save for getting the addresses I have to use for the sender to control my power plugs. I cannot see an obvious mapping between the pilight unit/id values and e.g. the sample mqtt topic OpenMQTTGateway/commands/MQTTtoRF2/CODE_8233228/UNIT_0/PERIOD_273
So the request: does anybody controls switches using the kaku_old protocol with their openmqttgateway and can tell me what addresses (i.e. mqtt topic) to use?
