Hi, in a previous post on compatible devices, 433 RF 4 CH relays, I reported back that the Sonoff RF Bridge can receive the remote button presses from the eBay nonamebrand.
Here is an example of what I receive on mqtt on button A (You would see that no Protocol is reported):
home/OpenMQTTGateway/SRFBtoMQTT
Button A:
{"raw":"2224013603AC4BC928","value":4966696,"delay":8740,"val_Thigh":310,"val_Tlow":940}
The remote works very well to its own 4 channel relay. Not to send same signal via mqtt to Sonoff bridge, onwards to the 4 Channel relay.
I tried SENDING the following, with and without the delay json pair, neither works:
home/OpenMQTTGateway/MQTTtoSRFB
{"value":4966689,"delay":8720}
Any ideas? Is it a Protocol issue? If I do receive the message, without a Protocol in the message, which protocol would it be?
