Shelly has recently introduced LoRa add-on modules for their Gen3 and Gen4 devices.
Does someone have an idea if OpenMQTTGateway supports / will support those (with LILYGO TTGO LoRa32 868 MHz board) – and if, how?
Its already supported. The LILYGO TTGO LoRa32 firmware files you can find ready to install on github.
You need most likely those 3 files for installation on that device:
ttgo-lora32-v21-bootloader.bin
ttgo-lora32-v21-firmware.bin
ttgo-lora32-v21-partitions.bin
If I understood correctly, the above mentioned OpenMQTTGateway firmware supports LoRa devices.
However, does someone already have experience how, in practice, the integration of a Shelly LoRa add-on is done, how to get f.ex. sensor readings and how to control Shelly device using LoRa?
Not sure of the availability of this addon, did you find it available to purchase somewhere ?
