Hello!
So, I gave away my OpenMQTT gateway to a friend, and thought I would just build a new one. But, I can not get 433 receive to work. I realize I must be missing something silly.
I have a generic ESP32 module with the following pinout. https://cdn.shopify.com/s/files/1/1509/1638/files/ESP-32_NodeMCU_Developmentboard_Pinout.pdf?v=1609851295
I have my STX-882 / SRX-882. My SRX has a pinout that seem to differ from the reference listed here RF gateway (433mhz/315mhz) | OpenMQTTGateway v0.9.5
The pinout of my module is GND, DATA, CS, VCC
I am using the ESP32-dev libraries.
So, the data pin of the SRX is connected to G16 of the ESP32 (And the data pin of the STX is G4).
Nothing I’ve tried seem make me be able to receive data. I’ve tried the “CS” pin in case my module would have happened to been mislabelled. But no joy.
My oscilloscope shows a nice enough pulse train on the data pin when i press a button on my remote,
But hey, BTLE works nice enough.
What the heckish might I have missed here?
Eddendum: Hm, interesting. If I look at the signal with oscilloscope I see a nice signal.
But when i have connected the data to my ESP pin, the signal seem to be constantly pulled low. Now I am confused big time.
{“mqtt_server”:“172.25.74.30”,“mqtt_port”:“1883”,“mqtt_user”:“redacted”,“mqtt_pass”:“redacted”,“mqtt_topic”:“openmqttgateway/”,“gateway_name”:“OpenMQTTGateway”}*WM: [3] allocating params bytes: 20
{“mqtt_server”:“172.25.74.30”,“mqtt_port”:“1883”,“mqtt_user”:“OZW”,“mqtt_pass”:“OZW”,“mqtt_topic”:“openmqttgateway/”,“gateway_name”:“OpenMQTTGateway”}N: RF_EMITTER_GPIO: 16
N: RF_RECEIVER_GPIO: 4
N: BLE scans interval: 55555
N: minrssi: 100
N: Low Power Mode: 0
N: Setup OpenMQTTGateway end
W: MQTT connection…
N: Connected to broker
N: Subject: /SYStoMQTT
