Hello, I have an OMG IR/RF mounted on an ESP32 (LolinD32). Today I replaced the old RF module with a recommended SRX882 and the Gateway stopped receiving RF signal.
I tested it with an oscilloscope and found that the SRX882’s DATA signal is less than 1V when it is on the ESP32. Outside the ESP32, the SRX882 again has a 3.3V DATA signal.
Does anyone know what’s going on
Thanks.
Hi!
Could you post a photo of your setup, how do you power the SRX882?
Hi boss.
Very simple setup on BreadBoard.
I fed the SRX882 with 3.3v of the D32(ESP32) and put the SRX882 DATA pin directly on the Pin27 of the ESP32.
With the old RXB6 receiver it worked normally. I changed just to follow what the documentation recommends.
Thanks for reply! ![]()
Sorry for this ugly photo. ![]()
Maybe this is the hint, could you connect it to 3.3v or 5v ?
Seems like the SRX882 has a very weak data output.
See https://github.com/sui77/rc-switch/issues/79#issuecomment-355782922
Trying to solve this myself.
