I’m looking for some suggestions on how to debug this. My installation won’t stay online for more than a few hours. I’ve tried a stock 1.5.1 and a 1.6 build. Could it be my board? Or the power supply?
You may be experiencing the same memory leak I’m seeing.
opened 11:42PM - 20 Jun 23 UTC
Before submitting a problem please check the troubleshooting section
https://docs.openmqttgateway.com/upload/troubleshoot.html
**Describe the bug**
Memory slowly decreasing over the course of the day. Eventually becomes unresponsive.
**To Reproduce**
Installed lilygo_rtl-433 from the web installer. Configured to connect to my MQTT server. Plotting memory and uptime in HomeAssistant.
**Expected behavior**
Stable memory usage.
**Screenshots**
See attached
**Environment (please complete the following information):**
* OpenMQTTGateway version used V1.6.0
* rtl_433
**Additional context**
Add any other context about the problem here.
* You should not have a compilation error if you use the versions of the libraries linked into the libraries folder, this badges show you the state of the compilation
[](https://github.com/1technophile/OpenMQTTGateway/actions)
* If you are not sure this is a bug or an enhancement post your question to the forum below
[](https://community.openmqttgateway.com)
