Support for LILYGO® LoRa32 V2.1_1.6.1 868 Mhz
Hi There
Following suggestions from this forum I have tried:
Using env: ttgo-lora32-v1-868, but changing reset pin from 14 to 23 in config_lora.h
I don’t get any signals.
Using env: lilygo-rtl_433, but changing frequency from 433.92 to 868 in config:RF.h
In the second case, in systomqtt I see
{“uptime”:473,“version”:“version_tag”,“discovery”:true,“ohdiscovery”:false,“env”:“lilygo-rtl_433”,“freemem”:115172,“mqttport”:“1883”,“mqttsecure”:false,“minfreemem”:55788,“tempc”:57.77778,“freestack”:3132,“rssi”:-66,“SSID”:“Alaya”,“BSSID”:“62:22:32:3A:2D:56”,“ip”:“192.168.1.254”,“mac”:“D4:D4:DA:97:6F:0C”,“actRec”:3,“mhz”:868,“RTLRssiThresh”:-107,“RTLRssi”:-122,“RTLAVGRssi”:-116,“RTLCnt”:0,“RTLOOKThresh”:15,“modules”:[“LilyGo_SSD1306”,“WebUI”,“rtl_433”]}
I’m trying to get data from a weatherstation. Sainlogic WS3500, but I guess it is an ecowitt. It says 868MHz on the back. I also tried to put 868.35 above. No luck.
Any ideas?
Hi, did you manage to resolve this? I’m having the same issue…
