I recently acquired a BLE tuya LED here and I wonder if the BLE openmqttgateway supports it?
If no any idea if an open source gateway compatible with home assistant exists?
Sincerely
Sincerely
Hello @rider45
It is very unlikely that your Tuya [inda-Ampoule LED bulb will be compatible with the OpenMQTTGateway, due to the Tuya proprietary protocols.
For Home Assistant you might want to try their own Tuya implementation, which might or might not include the RGB bulbs, or the possibility of reflashing it with an alternative firmware, as described in this thread.
Thank you very much for your answer ![]()
