Theengateway on rpi3b as external antenna for Jeedom Stops scanning after some hours
i’ve mount à fresh new install of my RSPI3b to use exclusively as external antenna.
I’ve installed TGW as à service
Launch the RSPI and i can see TGW collecting BLEA device and post them in my MQTT server on Jeedom.
I can observe everything is fine via MQTT explorer !
Everythings could be perfect, but after some time, 1,2,3 hours (more or less) :
TGW stop posting anything !!
I can see nothing special in the journal :
sudo journalctl -u TheengsGateway
-- Boot e6a49a23bf1a45b194168babda250451 --
avril 03 08:21:01 RSPI3bLapin systemd[1]: Started TheengsGateway.service - TheengsGateway Service.
avril 03 08:22:43 RSPI3bLapin systemd[1]: Stopping TheengsGateway.service - TheengsGateway Service...
avril 03 08:22:43 RSPI3bLapin systemd[1]: TheengsGateway.service: Deactivated successfully.
avril 03 08:22:43 RSPI3bLapin systemd[1]: Stopped TheengsGateway.service - TheengsGateway Service.
avril 03 08:22:43 RSPI3bLapin systemd[1]: TheengsGateway.service: Consumed 1.641s CPU time.
avril 03 08:22:43 RSPI3bLapin systemd[1]: Started TheengsGateway.service - TheengsGateway Service.
I’ve tried all the commands i know to restart the process
Nothing helps
Only a hard reboot can restart TGW service for some hours …
I’ve then decided to restart from scratch with à fresh new install
And tried installing TGW via the special Plugin TGW from Jeedom but
Exactly the same impact, works perfectly some hours and BUG!
I’ve tested Bookworm 32bit and Bookworm 64bit (the same result)
I’ve also tested with a SENA BLEA external antenna (the same result)
Can someone have an idea ??
What do you think am i doing wrong ?
Can it be an hardware issue ??
Cordialement
Alain
can you excuse my poor english ???
I think we can do that :wink:
Could you try to run the gateway with DEBUG log level and report the output when stopping ?
Good morning,
i think i’m ok now with log TGW log in Debug mode
But can you tell me the DEBIAN command tu see the Log ?
Thru jeedom the log are truncated …
Alain
Good evening,
Could you just launch the service without Jeedom ?
It should log the output in the command line.
I dont understand why he didnt want to start ? :
Prompt:~ $ sudo TheengsGateway.service
sudo: TheengsGateway.service : commande introuvable
sudo: TheengsGateway : commande introuvable
Prompt:~ $ python3 -m TheengsGateway -H 192.168.xxx.xxx -u tgw-user -p tgw-password
/usr/bin/python3: No module named TheengsGateway
Prompt:~ $ ^C
But :
Prompt:~ $ systemctl status TheengsGateway.service
● TheengsGateway.service - TheengsGateway Service
Loaded: loaded (/etc/systemd/system/TheengsGateway.service; enabled; preset: enabled)
Active: active (running) since Sun 2025-04-06 08:59:39 CEST; 1 day 5h ago
Main PID: 405 (python3)
Tasks: 1 (limit: 760)
CPU: 23min 58.048s
CGroup: /system.slice/TheengsGateway.service
└─405 /opt/TheengsGateway/bin/python3 -m TheengsGateway
Warning: some journal files were not opened due to insufficient permissions.
When i check the bluetooth :
systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
Active: active (running) since Sun 2025-04-06 08:59:41 CEST; 23h ago
Docs: man:bluetoothd(8)
Main PID: 412 (bluetoothd)
Status: “Running”
CPU: 8min 44.893s
CGroup: /system.slice/bluetooth.service
└─412 /usr/libexec/bluetooth/bluetoothd
What mean this warning ci-dessus ???
I’ve got the log in Debug level
But difficult to post because you can see all my iphone and perso ID everywhere
Can i send it in private message ??
If you want we could exchange easyer in french on jeedom community :
Thanks in advance
Alain
