This new version adds an impressive number of new compatible sensors:
- Hydractiva Digital-Amphiro/Oras
- April Brother-ABTemp
- April Brother-N03
- Oria/Brifit/SigmaWit/SensorPro-TH Sensor
- Otio/BeeWi-Door & Window sensor
- Qingping-CGDN1
- SmartDry-Laundry Sensor
- Switchbot-Motion Sensor
- Switchbot-Contact Sensor
- ThermoPro-TP357
- ThermoPro-TP358
- ThermoPro-TP359
The automatic creation of the sensors into Home Assistant through MQTT discovery, no need to manually create your entities and devices, they will appear directly into Configuration->Devices.
You can also Black List devices from the Device browser (click the + icon)
And finally, the application is now compatible with iOS!
What’s Changed
- Generic device implementation, when a device doesn’t match an existing widget we display the raw values by @emericg
- Enable device blacklist by @emericg
- Fix detection of THX1 thermometers by @emericg
- Implement MQTT discovery by @emericg
- Fixes and improvements by @emericg
- macOS App Icon fix by @DigiH in #4
- Init documentation by @1technophile in #6
- [DOCS] Add config.js and downgrade vuepress by @1technophile in #7
- Correct pound unit from lbs to lb by @DigiH in #12
- Correct abbreviation for minutes in settings by @DigiH in #11
- macOS preferences text without Windows/Linux references by @DigiH in #10
- Add google play badge by @1technophile in #17
- Add home image by @1technophile in #21
- Docs extension by @DigiH in #22
- Add cname and release event trigger by @1technophile in #23
- Add tutorial by @1technophile in #24
- [DOCS] Add tips by @1technophile in #26
- Small typo fixes and proposal for ellipsis by @DigiH in #31
- Vuepress Update packages by @1technophile in #34
- Add iOS app links by @1technophile in #33
- Recover previous device list version by @1technophile in #35
- Add more space for table by @1technophile in #36
- Bump Theengs Decoder to v095 by @1technophile in #37
- [DOCS] Add Home Assistant discovery documentation by @1technophile in #44
New Contributors
- @1technophile made their first contribution in #6
Full Changelog: Commits · theengs/app · GitHub
App Store and Apple logo are registered trademarks of Apple Inc.
