I’m trying to get my gateway to integrate with AWS IOT, following this guide:
I’m using the current development branch from github.
I’ve got the code updated to use the AWS thing certificates, built and uploaded to a Heltec Wifi LoRa 32 (v3), but when it’s trying to connect to the AWS endpoint, all I get is:
[ 22243][E][ssl_client.cpp:37] _handle_error(): [start_ssl_client():273]: (-29312) SSL - The connection indicated an EOF
[ 22244][E][WiFiClientSecure.cpp:144] connect(): start_ssl_client: -29312
W: failure_number_mqtt: 2
W: failed, ssl error code=-29312
I’ve checked the certificates are all correct, and I can access the endpoint. Any thoughts? Anyone else managed to get this working?
Dan
