I just have a question related to testing with PlatformIO. I have the OpenMQTTGateway running fine on a esp32, connected to my windows pc via usb. I want to monitor the serial to see in real time what is happening. Is it the right way to use the serial monitor in PlatformIO? I mean when I start the serial monitor I see the actions happening but are they coming from the uploaded code running in the esp32? Or is it platformIO that runs a separate task on the esp32?
From what I see in the screenshot yes they are.
OK, thanks, good to know. I anyway just tried a normal terminal application and it seems to do well enough if you just need serial monitoring
I have seen that after a while the “name” and “txpower” property is lost in the response like in this example
“id”:“d9:77:b9:4c:b8:5b”,“manufacturerdata”:“L”,“rssi”:-77,“distance”:7.119795}
When it works correctly, mostly in the beginning of the scan, it looks like this:
{“id”:“d9:77:b9:4c:b8:5b”,“name”:“MiniBeacon_10754”,“manufacturerdata”:“L”,“rssi”:-76,“txpower”:0,“distance”:6.44788}
You’re right and sometimes it could be more convenient to have a separate windows for the serial monitoring ![]()
If the properties are not found during the ESP32 scan indeed I don’t publish them, we do a function call to see if it have the expected value:
