WiFi network created by openmqttgateway
Since I flashed my sonoff rf bridge with openmqttgateway, I notice a new WiFi network with the name ESP_CCFFD2. What is it, and what is it used for?
Does it stay with this name if you do a wifi scan ? Indeed it looks like a temporary name for the esp or the host name that can appears on the network once connected.
It just stays there. I know its my sonoff rf bridge because it has the same name if I look in DD-WRT for the DHCP-address. I can connect to it, but do nothing.
Maybe try an erase all command and a reflash. This seems strange.
I compiled 0.9.2 using platformio,
  • platformio.ini : just erasing the ; in front of default_envs = rfbridge
  • user_config.h : just erasing the // in front of #define ZgatewaySRFB “SRFB” // Sonoff RF Bridge
    after successful compile, I opened the main.ini in arduino ide, compiled and flashed OTA
    now I have version 0.9.2 on the rfbridge, but the access point is still there
Thanks for your feedback.
Do you have another ESP32 to test with maybe it is a defective one.
Just flashed tasmota on it. The ESP_CCFFD2 access point is gone. So it seems a problem with OpenMQTTGateway.
Could you post please your platformio.ini file and user_config.h one (without credential) so as to try to reproduce your issue?
; PlatformIO Project Configuration File
;   Build options: build flags, source filter
;   Upload options: custom upload port, speed and extra flags
;   Library options: dependencies, extra library storages
;   Advanced options: extra scripting
; Please visit documentation for the other options and examples
; https://docs.platformio.org/page/projectconf.html
[platformio]
src_dir = main
;                                 ENVIRONMENT CHOICE                                   ;
;Uncomment the env line corresponding to your board and modules required,              ;
;you can also adapt the modules by removing the corresponding lines in the env detail  ;
;default_envs = esp32dev-all
;default_envs = esp32dev-rf
;default_envs = esp32dev-ir
;default_envs = esp32dev-ble
;default_envs = ttgo-lora32-v1
;default_envs = nodemcuv2-rf
;default_envs = nodemcuv2-ir
;default_envs = nodemcuv2-ble
;default_envs = nodemcuv2-all
;default_envs = uno-rf
;default_envs = uno-fastled
;default_envs = atmega-all
;                              ENVIRONMENTS PARAMETERS                                 ;
;Libraries and parameters shared accross environements                                 ;
[libraries]
arduinojson = ArduinoJson@5.13.4
pubsubclient = PubSubClient@2.7
rc-switch = 1technophile/rc-switch#90adb34
newremoteswitch = 1technophile/NewRemoteSwitch#8eb980e
ble = eos1d3/ESP32_BLE#9d6c1ed
irremoteesp = IRremoteESP8266@2.6.3
irremote = IRremote
lora = sandeepmistry/arduino-LoRa#f4a1d27
esppilight = ESPiLight@0.16.0
rfm69 = RFM69@4a6f77ad47
dht = DHT sensor library@1.3.0
unifiedsensor = Adafruit Unified Sensor@1.0.2
tsl2561 = Adafruit TSL2561@1.0.3
bme280 = SparkFun BME280@2.0.4
bmp180 = BMP180@efac46bd8d
ina226 = jarzebski/Arduino-INA226#968a684
a6lib = 1technophile/A6lib
wifimanager = tzapu/WiFiManager#c3ff582
ethernet = Ethernet
esp8266_mdns = esp8266_mdns
wire = Wire
fastled = FastLED
[env]
framework = arduino
  ${libraries.pubsubclient}
  ${libraries.arduinojson}
  -w ; supress all warnings
  '-DjsonPublishing=true'
  '-DjsonReceiving=true'
monitor_speed = 115200
[com]
esp8266_platform = espressif8266@1.8.0 ; 2.4.2
esp32_platform = espressif32@1.9.0
atmelavr_platform = atmelavr@1.13.0
[com-esp]
  ${env.lib_deps}
  ${libraries.wifimanager}
  ${env.build_flags}
  -DMQTT_MAX_PACKET_SIZE=1024
  '-DsimpleReceiving=true'
  '-DsimplePublishing=true'
  '-DTRACE=1'
[com-arduino]
  ${env.lib_deps}
  ${libraries.ethernet}
  ${env.build_flags}
  '-DTRACE=1'
[com-arduino-low-memory]
  ${env.lib_deps}
  ${env.build_flags}
  -DMQTT_MAX_PACKET_SIZE=128
;                                 ENVIRONMENTS LIST                                    ;
;List of environments that can be build                                                ;
[env:rfbridge]
board = esp8285
  ${libraries.esp8266_mdns}
  '-DZgatewaySRFB="SRFB"'
  '-DGateway_Name="OpenMQTTGateway_SRFB"'
board_build.flash_mode = dout
[env:esp32dev-all]
board = esp32dev
  ${libraries.ble}
  ${libraries.irremoteesp}
  ${libraries.lora}
  ${libraries.rfm69}
  ${libraries.rc-switch}
  ${libraries.newremoteswitch}
  ${libraries.bme280}
  ${libraries.bmp180}
  ${libraries.unifiedsensor}
  ${libraries.dht}
  ${libraries.tsl2561}
  ${libraries.ina226}
  ${libraries.fastled}
  '-DZgatewayRF="RF"'
  '-DZgatewayLORA="LORA"'
  '-DZgatewayRF2="RF2"'
  '-DZgatewayIR="IR"'
  '-DZgatewayBT="BT"'
  '-DZactuatorONOFF="ONOFF"'
  '-DZactuatorFASTLED="FASTLED"'
  '-DZsensorINA226="INA226"'
  '-DZsensorHCSR501="HCSR501"'
  '-DZsensorADC="ADC"'
  '-DZsensorBH1750="BH1750"'
  '-DZsensorBME280="BME280"'
  '-DZsensorTSL2561="TSL2561"'
  '-DZsensorDHT="DHT"'
  '-DZgatewayRFM69="RFM69"'
  '-DZsensorGPIOInput="GPIOInput"'
  '-DZsensorGPIOKeyCode="GPIOKeyCode"'
  '-DGateway_Name="OpenMQTTGateway_ESP32_ALL"'
[env:esp32dev-rf]
board = esp32dev
  '-DZgatewayRF="RF"'
  '-DGateway_Name="OpenMQTTGateway_ESP32_RF"'
[env:esp32dev-ir]
board = esp32dev
  '-DZgatewayIR="IR"'
  '-DGateway_Name="OpenMQTTGateway_ESP32_IR"'
[env:esp32dev-ble]
board = esp32dev
  ${libraries.ble}
  '-DZgatewayBT="BT"'
  '-DGateway_Name="OpenMQTTGateway_ESP32_BLE"'
[env:ttgo-lora32-v1]
board = ttgo-lora32-v1
  ${libraries.lora}
  '-DGateway_Name="OpenMQTTGateway_ESP32_LORA"'
[env:nodemcuv2-all]
board = nodemcuv2
  ${libraries.esppilight}
  ${libraries.rfm69}
  ${libraries.a6lib}
  ${libraries.bme280}
  ${libraries.bmp180}
  ${libraries.dht}
  ${libraries.ina226}
  ${libraries.wire}
  '-DZgatewayRF="RF"'
  '-DZgatewayIR="IR"'
  '-DZgatewayBT="BT"'
  '-DZgateway2G="2G"'
  '-DZgatewayPilight="Pilight"'
  '-DGateway_Name="OpenMQTTGateway_ESP8266_ALL"'
[env:nodemcuv2-ble]
board = nodemcuv2
  ${libraries.wire}
  '-DZgatewayBT="BT"'
  '-DGateway_Name="OpenMQTTGateway_ESP8266_BLE"'
[env:nodemcuv2-ir]
board = nodemcuv2
  '-DZgatewayIR="IR"'
  '-DGateway_Name="OpenMQTTGateway_ESP8266_IR"'
[env:nodemcuv2-rf]
board = nodemcuv2
  '-DZgatewayRF="RF"'
  '-DGateway_Name="OpenMQTTGateway_ESP8266_RF"'
[env:atmega-all]
platform = ${com.atmelavr_platform}
board = megaatmega2560
  ${com-arduino.lib_deps}
  ${libraries.irremote}
  ${libraries.rfm69}
  ${libraries.bme280}
  ${libraries.bmp180}
  ${libraries.dht}
  ${libraries.a6lib}
  ${libraries.ina226}
  ${com-arduino.build_flags}
  '-DZgatewayRF="RF"'
  '-DZgatewayRF="RF315"'
  '-DZgatewayIR="IR"'
  ;'-DZgatewayBT="BT"'
  ;'-DZsensorGPIOKeyCode="GPIOKeyCode"'
  '-DGateway_Name="OpenMQTTGateway_ATMEGA_ALL"'
[env:uno-rf]
board = uno
  ${com-arduino-low-memory.build_flags}
  '-DZgatewayRF="RF"'
  '-DGateway_Name="OpenMQTTGateway_UNO_RF"'
[env:uno-fastled]
board = uno
;extra_configs =
;  tests/*_env.ini
user_config.h :
OpenMQTTGateway - ESP8266 or Arduino program for home automation
Act as a wifi or ethernet gateway between your 433mhz/infrared IR signal and a MQTT broker
Send and receiving command by MQTT
This program enables to:
  • receive MQTT data from a topic and send signals corresponding to the received MQTT data
  • publish MQTT data to a different topic related to received signals
    Copyright: ©Florian ROBERT
    This file is part of OpenMQTTGateway.
    OpenMQTTGateway is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenMQTTGateway is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program. If not, see http://www.gnu.org/licenses/.
    #ifndef user_config_h
    #define user_config_h
    -------------------VERSION----------------------*/
    #define OMG_VERSION “0.9.2”
/-------------CONFIGURE WIFIMANAGER-------------(only ESP8266 & SONOFF RFBridge)/
  • The following parameters are set during the WifiManager setup process:
    • wifi_ssid
    • wifi_password
    • mqtt_user
    • mqtt_pass
    • mqtt_server
    • mqtt_port
  • To completely disable WifiManager, define ESPWifiManualSetup.
  • If you do so, please don’t forget to set these variables before compiling
  • Otherwise you can provide these credentials on the web interface after connecting
  • to the access point with your password (SSID: WifiManager_ssid, password: WifiManager_password)
/-------------DEFINE YOUR NETWORK PARAMETERS BELOW----------------/
#if defined(ESP8266)||defined(ESP32) // for nodemcu, weemos and esp8266
//#define ESPWifiManualSetup true //uncomment you don’t want to use wifimanager for your credential settings on ESP
#endif
#if defined(ESPWifiManualSetup) // for nodemcu, weemos and esp8266
#define wifi_ssid “wifi ssid”
#define wifi_password “wifi password”
#else // for arduino + W5100
const byte mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0x54, 0x95 }; //W5100 ethernet shield mac adress
#endif
#define WifiManager_password “your_password” //this is going to be the WPA2-PSK password for the initial setup access point
#define WifiManager_ssid “OpenMQTTGateway” //this is the network name of the initial setup access point
#define WifiManager_ConfigPortalTimeOut 120
#define WifiManager_TimeOut 5
/-------------DEFINE YOUR MQTT PARAMETERS BELOW----------------/
//MQTT Parameters definition
//#define mqtt_server_name “www.mqtt_broker.com” // instead of defining the server by its IP you can define it by its name, uncomment this line and set the correct MQTT server host name
char mqtt_user[20] = “xxxx”; // not compulsory only if your broker needs authentication
char mqtt_pass[30] = “xxxx”; // not compulsory only if your broker needs authentication
char mqtt_server[40] = “10.0.0.63”;
char mqtt_port[6] = “1883”;
#ifndef Gateway_Name
#define Gateway_Name “OpenMQTTGateway”
#endif
//uncomment the line below to integrate msg value into the subject when receiving
//#define valueAsASubject true
/-------------DEFINE THE MODULES YOU WANT BELOW----------------/
//Addons and module management, comment the Z line
//#define ZgatewayRF “RF” //ESP8266, Arduino, ESP32
//#define ZgatewayLORA “LORA” //ESP8266, Arduino, ESP32
//#define ZgatewayPilight “Pilight” //ESP8266, Arduino, ESP32
//#define ZgatewayBT “BT” //ESP8266, ESP32
//#define Zgateway2G “2G” //ESP8266, Arduino, ESP32
//#define ZgatewayRFM69 “RFM69” //ESP8266, Arduino, ESP32
//#define ZactuatorONOFF “ONOFF” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZsensorINA226 “INA226” //ESP8266, Arduino, ESP32
//#define ZsensorHCSR501 “HCSR501” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZsensorADC “ADC” //ESP8266, Arduino, ESP32
//#define ZsensorBH1750 “BH1750” //ESP8266, Arduino, ESP32
//#define ZsensorTSL2561 “TSL2561” //ESP8266, Arduino, ESP32
//#define ZsensorBME280 “BME280” //ESP8266, Arduino, ESP32
//#define ZsensorDHT “DHT” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZsensorGPIOKeyCode “GPIOKeyCode” //ESP8266, Arduino, ESP32
//#define ZsensorGPIOInput “GPIOInput” //ESP8266, Arduino, ESP32
//#define ZmqttDiscovery “HADiscovery”//ESP8266, Arduino, ESP32, Sonoff RF Bridge
//#define ZactuatorFASTLED “FASTLED” //ESP8266, Arduino, ESP32, Sonoff RF Bridge
/-------------DEFINE YOUR ADVANCED NETWORK PARAMETERS BELOW----------------/
//#define MDNS_SD //uncomment if you want to use mdns for discovering automatically your ip server, please note that MDNS with ESP32 can cause the BLE to not work
#define maxMQTTretry 4 //maximum MQTT connection attempts before going to wifi setup
//set minimum quality of signal so it ignores AP’s under that quality
#define MinimumWifiSignalQuality 8
// these values are only used if no dhcp configuration is available
const byte ip[] = { 192, 168, 1, 99 }; //ip adress
const byte gateway[] = { 10, 0, 0, 1 }; //ip adress, if first value is different from 0 advanced config network will be used and you should fill gateway & dns
const byte Dns[] = { 0, 0, 0, 0 }; //ip adress, if first value is different from 0 advanced config network will be used and you should fill gateway & dns
const byte subnet[] = { 255, 255, 255, 0 }; //ip adress
/-------------DEFINE YOUR MQTT ADVANCED PARAMETERS BELOW----------------/
#define Base_Topic “home/”
#define version_Topic Base_Topic Gateway_Name “/version”
#define will_Topic Base_Topic Gateway_Name “/LWT”
#define will_QoS 0
#define will_Retain true
#define will_Message “offline”
#define Gateway_AnnouncementMsg “online”
#define jsonPublishing true //comment if you don’t want to use Json publishing (one topic for all the parameters)
//example home/OpenMQTTGateway_ESP32_DEVKIT/BTtoMQTT/4XXXXXXXXXX4 {“rssi”:-63,“servicedata”:“fe0000000000000000000000000000000000000000”}
#define jsonReceiving true //comment if you don’t want to use Json reception analysis
//#define simplePublishing true //comment if you don’t want to use simple publishing (one topic for one parameter)
//example
// home/OpenMQTTGateway_ESP32_DEVKIT/BTtoMQTT/4XXXXXXXXXX4/rssi -63.0
// home/OpenMQTTGateway_ESP32_DEVKIT/BTtoMQTT/4XXXXXXXXXX4/servicedata fe0000000000000000000000000000000000000000
#define simpleReceiving true //comment if you don’t want to use old way reception analysis
/-------------DEFINE YOUR OTA PARAMETERS BELOW----------------/
#define ota_hostname Gateway_Name
#define ota_password “OTAPASSWORD”
#define ota_port 8266
/-------------DEFINE PINs FOR STATUS LEDs----------------/
#ifdef ESP8266
#define led_receive 40
#define led_send 42
#define led_info 44
#elif ESP32
#define led_send 42
#define led_info 44
#elif AVR_ATmega2560 //arduino mega
#define led_send 42
#define led_info 44
#else //arduino uno/nano
#define led_send 42
#define led_info 44
#endif
// VCC ------------D|-----------////\ ----------------- Arduino PIN
// LED Resistor 270-510R
/----------------------------OTHER PARAMETERS-----------------------------/
/-------------------CHANGING THEM IS NOT COMPULSORY-----------------------/
/----------------------------USER PARAMETERS-----------------------------/
#ifdef ZgatewaySRFB
#define SERIAL_BAUD 19200
#else
#define SERIAL_BAUD 115200
#endif
/--------------MQTT general topics-----------------/
// global MQTT subject listened by the gateway to execute commands (send RF, IR or others)
#define subjectMQTTtoX Base_Topic Gateway_Name “/commands/#”
#define subjectMultiGTWKey “toMQTT”
#define subjectGTWSendKey “MQTTto”
//variables to avoid duplicates
#define time_avoid_duplicate 3000 // if you want to avoid duplicate mqtt message received set this to > 0, the value is the time in milliseconds during which we don’t publish duplicates
#if defined(ESP8266) || defined(ESP32) || defined(AVR_ATmega2560) || defined(AVR_ATmega1280)
#define JSON_MSG_BUFFER 512 // Json message max buffer size, don’t put 1024 or higher it is causing unexpected behaviour on ESP8266
#else // boards with smaller memory
#define JSON_MSG_BUFFER 64 // Json message max buffer size, don’t put 1024 or higher it is causing unexpected behaviour on ESP8266
#endif
#define TimeBetweenReadingSYS 120000 // time between system readings (like memory)
#define subjectSYStoMQTT Base_Topic Gateway_Name “/SYStoMQTT”
//#define subjectTRACEtoMQTT Base_Topic Gateway_Name “/log” //uncomment if you want to see traces on /log topic
/-------------------ACTIVATE TRACES----------------------/
#define TRACE 1 // commented = trace off, uncommented = trace on
#endif
Well, the access point is back. I decided to flash 0.9.1 again on it (since I did not want to change all my automations in HA) I thought it was gone, but when putting it back in the case (and a second reboot), it was there again.
It does not seem to be limited to the rfbridge
The ESP_BF4FE8 is a nodemcu flashed with 0.9.2
Bye the way : how do you disable the automatic HA discovery ? The 0.9.2 makes my automations throw a lot of errors.
I found the problem (testing with my nodemcu)
As soon as you open de arduino ide, it creates an OTA accesspoint. And it stays created, even after a reboot. The only way to get rid of it is to do a serial reflash, erasing all data first.
