Hi
I’ve just discovered that when compiling using PlatformIO, the wifi_password setting override has to be typed without quotes, ie:
-Dwifi_password="password!" <-Works
while
'-Dwifi_password="password!"' <-Does not work
(I’ve also tried triple-backlash escaping the exclamation mark btw, not knowing which chars are considered special, but that did not change the observed behaviour)
Now, to be honest, in the main docs it is correctly listed without single quotes, but elsewhere else in the code, it shows with quotes, e.g. in:
environment.ini: Line 349: ; '-Dwifi_password="WIFI_PASSWORD"'
prod_env.ini.example Line 76: '-Dwifi_password="MyWiFiAPPassword"'
is it a typo or I’m missing something? (eg: Why this is the only setting override that does not require to be single-quoted?)
