I’m verry busy these days here but I have another problem.
I upload the esp32dev-ble image to my NodeMCU ESP-32S. After connecting to the OMG wifi network I got the wifi manager like expected, but after I pressed the configure wifi button it kept spinning.
I found in the serial monitor that a request handler isn’t working:
N: OpenMQTTGateway Version: v0.9.16
*WM: [1] Free heap: 152180
*WM: [1] ESP-IDF version: v3.3.5-1-g85c43024c
[E][WiFiSTA.cpp:221] begin(): connect failed!
N: Connect your phone to WIFI AP: OpenMQTTGateway_ESP32_BLE with PWD: your_password
*WM: [1] AutoConnect
*WM: [2] Connecting as wifi client...
*WM: [1] STA static IP:
*WM: [3] WIFI station disconnect
*WM: [1] No saved credentials, skipping wifi
*WM: [2] Connection result: WL_NO_SSID_AVAIL
*WM: [3] lastconxresult: WL_NO_SSID_AVAIL
*WM: [1] AutoConnect: FAILED
*WM: [2] AccessPoint set password is VALID
*WM: [1] your_password
*WM: [3] WiFi station enable
*WM: [2] Disabling STA
*WM: [2] Enabling AP
*WM: [1] StartAP with SSID: OpenMQTTGateway_ESP32_BLE
*WM: [1] AP IP address: 192.168.4.1
*WM: [3] setupConfigPortal
*WM: [1] Starting Web Portal
*WM: [3] dns server started with ip: 192.168.4.1
*WM: [2] HTTP server started
*WM: [2] WiFi Scan ASYNC started
*WM: [2] Config Portal Running, blocking, waiting for clients...
*WM: [2] WiFi Scan ASYNC completed in 5315 ms
*WM: [2] WiFi Scan ASYNC found: 10
*WM: [2] Portal Timeout In 92 seconds
[E][WebServer.cpp:633] _handleRequest(): request handler not found
*WM: [3] -> www.msftconnecttest.com
*WM: [2] <- Request redirected to captive portal
*WM: [2] <- HTTP Root
*WM: [3] -> 192.168.4.1
*WM: [3] lastconxresulttmp: WL_IDLE_STATUS
*WM: [3] lastconxresult: WL_DISCONNECTED
*WM: [2] <- HTTP Wifi
*WM: [2] Scan is cached 38339 ms ago
*WM: [1] 10 networks found
*WM: [2] DUP AP:
*WM: [2] DUP AP:
*WM: [2] DUP AP:
*WM: [2] DUP AP:
*WM: [2] DUP AP:
*WM: [2] DUP AP:
*WM: [2] DUP AP:
*WM: [2] DUP AP:
*WM: [2] DUP AP:
*WM: [2] AP: 0
*WM: [3] Sent config page
**[E][WebServer.cpp:633] _handleRequest(): request handler not found**
*WM: [2] WiFi Scan ASYNC completed in 5319 ms
*WM: [2] WiFi Scan ASYNC found: 9
Also I get disconnected from the OMG hostspot because it restarts after this.
Manual configuration works, but that’s very annoying, because I don’t like hard coded password ect.
