I have an ESP32 board, and I want to set up the OpenMQTTGateway to listen to my Miflora Plant sensors. Later, it should also listen to 433 Mhz signals, but I don’t have the hardware for that connected yet. So for the moment, it should only do the BLE devices.I have gotten so far that it connects to my wireless network, but then it seems to “hang”. The log looks like this:
*WM: [2] Connection result: WL_CONNECTED
*WM: [3] lastconxresult: WL_CONNECTED
*WM: [1] AutoConnect: SUCCESS
*WM: [1] STA IP Address: 192.168.179.82
connected...yeey :)
saving config
{"mqtt_server":"192.168.178.222","mqtt_port":"1883","mqtt_user":"","mqtt_pass":"","mqtt_topic":"home/","gateway_name":"OpenMQTTGateway1"}OpenMQTTGateway mac:
24:6F:28:96:90:3C
OpenMQTTGateway ip:
192.168.179.82
1883
192.168.178.222
Bosch BME280 Initialized - Result of .begin(): 0x0
No TSL2561 detected
TSL2561 Initialized. Printing detials now.
Sensor: TSL2561
Driver Ver: 1
Unique ID: 12345
Max Value: 17000.00 lux
Min Value: 1.00 lux
Resolution: 1.00 lux
IR_EMITTER_PIN
14
IR_RECEIVER_PIN
26
ZgatewayIR setup done
ZgatewayLORA setup failed!
The last thing I always see in the log is the “ZgatewayLORA setup failed!”.
Any ideas why that happens? What does the ZgatewayLORA do?
Thanks in advance &
Kind Regards,
judith_21
