I am trying to install OMG on wt32-eth01 with RFM69. I can successfully install OMG without RFM69 support, but as soon as I add RFM69 gateway, boards boots and then immediately crashes. If I remove ‘-DZgatewayRFM69=“RFM69”’ from the ini file, OMG installs and works without any issues. The same behaviour occurs no matter if I connect the radio or not.
This is my _env.ini file:
[env:wt32-eth01]
board = wt32-eth01
board_build.mcu = esp32
board_build.f_cpu = 240000000L
framework = arduino
monitor_speed = 115200
upload_protocol = esptool
${libraries.rfm69}
${libraries.rfm69spi}
${libraries.wifimanager32}
${libraries.Ethernet}
${libraries.pubsubclient}
${libraries.arduinojson}
${libraries.arduinolog}
‘-DLOG_LEVEL=LOG_LEVEL_TRACE’
‘-DOMG_VERSION=“v1.7.0”’
‘-DGateway_Name=“rfm69gw1”’
‘-DBase_Topic=“rfm69gw1/”’
‘-DZmqttDiscovery=“HADiscovery”’
‘-DESP32_ETHERNET=true’
‘-DETH_PHY_TYPE=ETH_PHY_LAN8720’
‘-DETH_PHY_ADDR=1’
‘-DETH_PHY_POWER=16’
‘-DETH_CLK_MODE=ETH_CLOCK_GPIO0_IN’
‘-DNETWORKID=101’
‘-DNODEID=1’
‘-DFREQUENCY=“RF69_868MHZ”’
‘-DIS_RFM69HCW=true’
‘-DRFM69_CS=5’
‘-DRFM69_IRQ=2’
‘-DRFM69_RST=4’
This is serial output when the board boots and crashes:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13924
ho 0 tail 12 room 4
load:0x40080400,len:3600
entry 0x400805f0
N:
[ 130][E][Preferences.cpp:50] begin(): nvs_open failed: NOT_FOUND
N: SYS config not found
N: OpenMQTTGateway Version: v1.7.0
T: mounting FS…
T: mounted file system
T: reading config file
T: opened config file
“mqtt_server”: “192.168.100.100”,
“mqtt_port”: “1883”,
“mqtt_user”: “user”,
“mqtt_pass”: “*",
“mqtt_topic”: “rfm69gw1/”,
“gateway_name”: “rfm69gw1”,
“mqtt_broker_secure”: false,
“mqtt_broker_cert”: “”,
“mqtt_ss_index”: 0,
“ota_server_cert”: “”,
“ota_pass”: "”
T: parsed json, size: 388
N: Config loaded from flash
T: Spl eth cfg
T: Ethernet Started
N: Ethernet Connected
T: Connecting to Ethernet
T: .
T: OpenMQTTGateway MAC: A0:A3:B3:21:AC:47
T: OpenMQTTGateway IP: 192.168.100.110
T: OpenMQTTGateway link speed: 100 Mbps
T: .
T: OpenMQTTGateway mac: A0:A3:B3:21:AC:44
T: OpenMQTTGateway ip: 0.0.0.0
T: Port: 1883
T: Mqtt server: 192.168.100.100
��W�U�WU�WU�W�UW�UWUW�U�W�U�WUW�U�W�U�WUUWU�WUWUWUWU�U�WUWU�WUWU�WU��m
When the board boots, I can ping it for one or two times and then it crashes. After it crashes I can’t even ping the board. If I disable RFM69, board works without any issues and I can ping it constantly. Also, when it boots without RFM69 it connects to MQTT and sends MQTT messages without any issues.
And ideas on how can I make this work?
