I assume it is the HHCCJCY01HHCC Mi Floras which you have.
The battery value is much the same issue as with the voltage in the related thread
So you either already have got the battery values coming through after the initial 60 minutes, or you should get them very soon
the other two intervals are not related to this, only the connect interval.
