Hi, I have noticed that I have about 1m range when I use IR nodemcu. I have tried different IR diodes and still the same. I have use setup based on openMqttGateway github page for IR receive and send. Any one else having issue with it?
Thank You
Hi, my range is around 3 meters, if you take a look to this thread here is another implementation example :
I easily get about 4 meters… I only use a 2N2222A without any resistor… Works just fine…
Is this on 5 volt or 3 volt or a combination of both ?
Its on 3.3 v only, simply connecting it to pin and power via transistor.
Thank you very much for the information.
Regards.
