Build error with Arduino Mega + Ethernet Shield + Platformio on Mac
Hi - I am using Platforio for a while on Mac OSX to program ESP32 and 8266 boards, also I programmed ESP32 with OMG 0.9.3 version without issues including RF and BLE modules.
I decided to move away from ESP32 and build OMG 0.9.3 on Arduino Mega + W5100 ethernet shield + Bluetooth + RF 433Mhz modules.
My first attempt to build on a Mac with Platformio failed, ZgatewayBT.ino is missing, however it is in the main folder.
I have received the following errors:
Processing atmega-all (platform: atmelavr@1.13.0; board: megaatmega2560; framework: arduino)
Verbose mode can be enabled via -v, --verbose option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR 1.13.0 > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
HARDWARE: ATMEGA2560 16MHz, 8KB RAM, 248KB Flash
PACKAGES:
  • framework-arduinoavr 3.10623.190424 (1.6.23)
  • toolchain-atmelavr 1.50400.190710 (5.4.0)
Converting main.ino
/Users/balazsadam/Documents/PlatformIO/OpenMQTTGateway-0.9.3-MEGA/main/main.ino:37:0: warning: “array_size” redefined
#define array_size 4
/Users/balazsadam/Documents/PlatformIO/OpenMQTTGateway-0.9.3-MEGA/main/main.ino:32:0: note: this is the location of the previous definition
#define array_size 12
Unicode decode error has occurred, please remove invalid (non-ASCII or non-UTF8) characters from /Users/balazsadam/Documents/PlatformIO/OpenMQTTGateway-0.9.3-MEGA/main/main.ino.cpp file
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 50 compatible libraries
Scanning dependencies…
Dependency Graph
|-- 2.7
|-- 5.13.4
|-- 2.0.0
| |-- 1.0
|-- 2.3.3
| | |-- 1.0
| |-- 1.0
|-- 2.6.2 #90adb34
|-- #8eb980e
|-- 2.0.4
| |-- 1.0
| |-- 1.0
| |-- 1.0
|-- 1.0.2
|-- 1.3.0
| |-- 1.0.2
|-- 1.0.3
| |-- 1.0
| |-- 1.0.2
|-- #68142af
| |-- 1.0
|-- #968a684
| |-- 1.0
|-- 3.3.2
| |-- 1.0
| |-- 1.0
|-- 1.0
|-- 0.16.2
|-- 1.0
|-- 1.0
Building in release mode
Compiling .pio/build/atmega-all/src/main.ino.cpp.o
Compiling .pio/build/atmega-all/lib45b/PubSubClient_ID89/PubSubClient.cpp.o
Archiving .pio/build/atmega-all/libe10/libArduinoJson_ID64.a
Indexing .pio/build/atmega-all/libe10/libArduinoJson_ID64.a
/Users/balazsadam/Documents/PlatformIO/OpenMQTTGateway-0.9.3-MEGA/main/ZgatewayBT.ino:35:18: fatal error: vector: No such file or directory
compilation terminated.
Compiling .pio/build/atmega-all/lib056/SPI/SPI.cpp.o
*** [.pio/build/atmega-all/src/main.ino.cpp.o] Error 1
========================== [FAILED] Took 4.96 seconds ==========================
Environment Status Duration
rfbridge IGNORED
esp32dev-all IGNORED
esp32dev-rf IGNORED
esp32dev-pilight IGNORED
esp32dev-ir IGNORED
esp32dev-ble IGNORED
esp32-m5stick-ble IGNORED
esp32-m5stack-ble IGNORED
esp32-m5stick-c-ble IGNORED
ttgo-lora32-v1 IGNORED
nodemcuv2-all IGNORED
nodemcuv2-ble IGNORED
nodemcuv2-ir IGNORED
nodemcuv2-rf IGNORED
rf-wifi-gateway IGNORED
nodemcuv2-rf2 IGNORED
nodemcuv2-pilight IGNORED
sonoff-basic IGNORED
sonoff-basic-rfr3 IGNORED
atmega-all FAILED 00:00:04.957
uno-rf IGNORED
uno-fastled IGNORED
==================== 1 failed, 0 succeeded in 00:00:04.957 ====================
What do I do wrong?
Thanks,
Balazs
Did you modified the atmega-all environment or is it the stock one?
In platformio.ini I enabled this:
default_envs = atmega-all
[env:atmega-all]
platform = ${com.atmelavr_platform}
board = megaatmega2560
${com-arduino.lib_deps}
${libraries.irremote}
${libraries.rfm69}
${libraries.rc-switch}
${libraries.newremoteswitch}
${libraries.bme280}
${libraries.bmp180}
${libraries.unifiedsensor}
${libraries.dht}
${libraries.tsl2561}
${libraries.a6lib}
${libraries.ina226}
${libraries.fastled}
${com-arduino.build_flags}
‘-DZgatewayRF=“RF”’
;’-DZgatewayRF=“RF315”’
;’-DZgatewayRF2=“RF2”’
;’-DZgatewayIR=“IR”’
‘-DZgatewayBT=“BT”’
‘-DZactuatorONOFF=“ONOFF”’
;’-DZactuatorFASTLED=“FASTLED”’
;’-DZsensorINA226=“INA226”’
;’-DZsensorHCSR501=“HCSR501”’
;’-DZsensorADC=“ADC”’
;’-DZsensorBH1750=“BH1750”’
;’-DZsensorBME280=“BME280”’
;’-DZsensorTSL2561=“TSL2561”’
;’-DZsensorDHT=“DHT”’
;’-DZgatewayRFM69=“RFM69”’
;’-DZsensorGPIOInput=“GPIOInput”’
;’-DZsensorGPIOKeyCode=“GPIOKeyCode”’
‘-DZmqttDiscovery=“HADiscovery”’
‘-DsimplePublishing=true’
‘-DGateway_Name=“OpenMQTTGateway_ATMEGA_ALL”’
Could you try maybe to redownload the code, check that atmega-all is building properly. And if yes, remove the unnecessaries gateways and sensors.
Atmega-all with ZgatewayBT added has an issue with missing vector library:
D:/Users/Florian/Documents/GitHub/OpenMQTTGateway/main/ZgatewayBT.ino:35:18: fatal error: vector: No such file or directory
*** [.pio\build\atmega-all\src\main.ino.cpp.o] Error 1
I am getting the same issue in Ardunio IDE with Mega + W5100. How can this be resolved?
> ResolveLibrary(vector)
>   -> candidates: []ZgatewayBT:45:12: fatal error: vector: No such file or directory
>  #  include <vector>
It seems that the vector library is not found with Arduino framework.
So we need to find one compatible.
@diablo I’ve built it successfully with the following modifications:
[env:atmega-ble]
  https://github.com/mike-matera/ArduinoSTL
  '-DZgatewayBT="BT"'
  '-DGateway_Name="OpenMQTTGateway_ATMEGA_BLE"'
And add:
#include <ArduinoSTL.h>
at line 44 of ZgatewayBT.ino.
Please let me know if it works for you, if OK I will add it to the repository.
It appears to compile without issues in PlatformIO. When compiling in Arduino I get the following errors even after importing the library.
C:\Program Files (x86)\Arduino\libraries\ArduinoSTL-master\src\del_opnt.cpp:25:56: error: 'nothrow_t' in namespace 'std' does not name a type
 _UCXXEXPORT void operator delete(void* ptr, const std::nothrow_t& ) throw() {
C:\Program Files (x86)\Arduino\libraries\ArduinoSTL-master\src\del_ops.cpp:25:50: error: 'std::size_t' has not been declared
 _UCXXEXPORT void operator delete(void* ptr, std::size_t) throw(){
While it compiles in PlatformIO without errors, I have not tried it on the hardware as I returned the Bluetooth temperature sensor when I didn’t know if this would be fixed. I can order another one but my preference would be the cheaper PiLight Digoo R8S or R8H sensors. The Bluetooth sensors are $15 each and the PiLight ones are $5 each which will add up quickly because I want to use about 10 of them.
To compile with Arduino IDE , you must downgrade board to Arduino AVR 1.8.2
