Hello, i can see in logs the following warnings. Is there any solution to this? Thanks
Source: helpers/template.py:2345
First occurred: February 11, 2024 at 5:00:23 PM (1069 occurrences)
Last logged: 9:14:24 AM
Template variable warning: 'dict object' has no attribute 'disc' when rendering '{{ value_json.disc }}'
Template variable warning: 'dict object' has no attribute 'ohdisc' when rendering '{{ value_json.ohdisc }}'
Template variable warning: 'dict object' has no attribute 'enablecrc' when rendering '{{ value_json.enablecrc }}'
Template variable warning: 'dict object' has no attribute 'invertiq' when rendering '{{ value_json.invertiq }}'
Template variable warning: 'dict object' has no attribute 'onlyknown' when rendering '{{ value_json.onlyknown }}'
