ladaowner:
{“id”:“58:2d:34:52:4f:09”,“rssi”:-72,“distance”:4.287841,“servicedata”:“080c094f52342d580104f3005101020164”,“servicedatauuid”:“0000fdcd-0000-1000-8000-00805f9b34fb”}
Should you see {"tem":24,3,"hum":33.7} ?
{“id”:“58:2d:34:52:4f:09”,“rssi”:-72,“distance”:4.287841,“servicedata”:“080c094f52342d580104db008e01020164”,“servicedatauuid”:“0000fdcd-0000-1000-8000-00805f9b34fb”}
Should you see {"tem":21,9,"hum":39,8} ?
Should but dont same story for mi Flora.
For the CGD1, if you are using ESP32 and uploading with Arduino IDE or PIO could you replace line 510 of ZgatewayBT.ino:
if (strstr(BLEdata["servicedata"].as<char *>(), "080caf") != NULL)
by
if (strstr(BLEdata["servicedata"].as<char *>(), "080c09") != NULL)
and say if it works
Will give it a try later today. Thanks for all the help btw.
ladaowner:
Success!!! You da man!!!
Great,
ladaowner:
Now for the Mi flora
Try to replace this line
pos = strpos(service_data, "209800");
by
pos = strpos(service_data, "029800");
Testing right now and I will report back later. Where is your donate page and I will send you a beer.
Guessing these bits (once confirmed) will make it into 0.9.5?
I can confirm that both the alarm clock and Mi Flora are now working!
Perfect, I will change the way the services are detected.
Spoke too soon, 4 flora sensors appear in HA but never get populated with any values. Just checking the MQTT logs
{“id”:“c4:7c:8d:61:7d:ae”,“name”:“Flower care”,“rssi”:-84,“distance”:13.81901,“servicedata”:“3102980010ae7d618d7cc40d”,“servicedatauuid”:“0000fe95-0000-1000-8000-00805f9b34fb”}
{“id”:“c4:7c:8d:61:7d:ae”,“name”:“Flower care”,“rssi”:-81,“distance”:10.46739,“servicedata”:“310298000fae7d618d7cc40d”,“servicedatauuid”:“0000fe95-0000-1000-8000-00805f9b34fb”}
Is your mi flora updated with the last version of the firmware?
How can you tell? Nothing in the Mi Home app about firmware updates for the Mi Flora
Normally it is the same thing as the clock, you should be able to see the version and update it, if it is not the last one.
ha you need to use a different app to get v 3.2.2.
app is called Flower Care by Lifestyle
3 minutes and still nothing in HA
by
flipped this back and now with new firmware it appears to be working
Once again thanks for all the help.
If you agree I will ask for your help in testing a refactoring of this.
fine by me, I’ll look out for the new version.
olibos
July 14, 2020, 7:20am
40
Hello, does OMG enable to set time and alarm on this device?
