No it only retrieves temperature, humidity and battery.
Thank you. I was afraid of that
Note: Just flash an ESP32 with OMG and it’s excelent!
Thanks for the feedback
May be need to add
|| strstr(service_data, “080ca0”) != NULL
at line
I occasionally get
“model”: “CGD1”, “tem”: 24, “hum”: 53.6
after adding this line, but more often I get short servicedata like this:
“servicedata”: “30587605a3a05252342d5808”
Could you post some examples of service data that you are receiving that match your criteria?
You mean remove the line
from the code and show the data returned without this line?
Data for 1 hour with “080ca0” added to the code
09.09.2020 18:13:31
{“id”:“58:2D:34:52:52:A0”,“rssi”:-73,“distance”:4.756481,“servicedata”:“30587605d5a05252342d5808”}
09.09.2020 18:12:31(-59.93 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-73,“distance”:4.756481,“servicedata”:“30587605d3a05252342d5808”}
09.09.2020 18:11:02(-89.29 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-80,“distance”:9.521558,“servicedata”:“58587605d0a05252342d58901f54f8e448000029d19668”}
09.09.2020 18:08:58(-2.07 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-82,“distance”:11.4949,“servicedata”:“30587605cba05252342d5808”}
09.09.2020 18:05:39(-3.31 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-80,“distance”:9.521558,“servicedata”:“30587605c5a05252342d5808”}
09.09.2020 18:03:18(-2.34 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-80,“distance”:9.521558,“model”:“CGD1”,“tem”:23.5,“hum”:53.3}
09.09.2020 18:02:07(-71.46 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-73,“distance”:4.756481,“servicedata”:“30587605bfa05252342d5808”}
09.09.2020 18:01:16(-50.89 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-82,“distance”:11.4949,“model”:“CGD1”,“tem”:23.5,“hum”:53.2}
09.09.2020 18:00:03(-72.54 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-80,“distance”:9.521558,“model”:“CGD1”,“tem”:23.6,“hum”:53.1}
09.09.2020 17:58:57(-66.49 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-74,“distance”:5.270232,“model”:“CGD1”,“tem”:23.6,“hum”:53.1}
09.09.2020 17:57:43(-74.05 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-74,“distance”:5.270232,“model”:“CGD1”,“tem”:23.6,“hum”:53}
09.09.2020 17:56:48(-54.74 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-74,“distance”:5.270232,“servicedata”:“30587605b5a05252342d5808”}
09.09.2020 17:55:33(-74.71 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-80,“distance”:9.521558,“servicedata”:“30587605b3a05252342d5808”}
09.09.2020 17:54:36(-57.27 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-82,“distance”:11.4949,“servicedata”:“58587605b0a05252342d58ef704d094800002c3a7245”}
09.09.2020 17:52:13(-2.39 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-82,“distance”:11.4949,“model”:“CGD1”,“tem”:24,“hum”:52.3}
09.09.2020 17:49:06(-3.12 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-73,“distance”:4.756481,“servicedata”:“30587605a5a05252342d5808”}
09.09.2020 17:46:58(-2.13 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-86,“distance”:16.54559,“model”:“CGD1”,“tem”:24.4,“hum”:51.1}
09.09.2020 17:45:52(-65.98 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-87,“distance”:18.07764,“servicedata”:“305876059fa05252342d5808”}
09.09.2020 17:42:20(-3.52 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-88,“distance”:19.7325,“model”:“CGD1”,“tem”:24.4,“hum”:51.1}
09.09.2020 17:38:11(-4.15 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-89,“distance”:21.51847,“model”:“CGD1”,“tem”:24.5,“hum”:51}
09.09.2020 17:34:56(-3.25 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-88,“distance”:19.7325,“model”:“CGD1”,“tem”:24.5,“hum”:51}
09.09.2020 17:34:02(-53.85 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-91,“distance”:25.51913,“servicedata”:“3058760587a05252342d5808”}
09.09.2020 17:29:09(-4.89 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-88,“distance”:19.7325,“model”:“CGD1”,“tem”:24.5,“hum”:50.9}
09.09.2020 17:27:13(-115.08 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-91,“distance”:25.51913,“servicedata”:“305876057ba05252342d5808”}
09.09.2020 17:25:51(-82.47 seconds)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-87,“distance”:18.07764,“model”:“CGD1”,“tem”:24.6,“hum”:50.9}
09.09.2020 17:18:30(-7.36 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-90,“distance”:23.44428,“servicedata”:“3058760569a05252342d5808”}
09.09.2020 17:15:56(-2.57 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-91,“distance”:25.51913,“servicedata”:“3058760565a05252342d5808”}
09.09.2020 17:10:26(-5.5 minutes)
{“id”:“58:2D:34:52:52:A0”,“rssi”:-91,“distance”:25.51913,“servicedata”:“305876055ba05252342d5808”}
Also, with the ZmqttDiscovery option enabled, battery data will not be included in the topic.
Version 1.0.1_0067
Data without “080ca0” added to the code
09.09.2020 20:33:37
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-61,“distance”:1.274439,“servicedata”:“30587605e5a05252342d5808”}
09.09.2020 20:32:36(-60.93 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-72,“distance”:4.287841,“servicedata”:“080ca05252342d580104ee000f02020164”}
09.09.2020 20:31:33(-62.79 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-71,“distance”:3.860897,“servicedata”:“080ca05252342d580104ee000f02020164”}
09.09.2020 20:30:23(-70.09 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“080ca05252342d580104ed001002020164”}
09.09.2020 20:29:14(-68.53 seconds)
09.09.2020 20:28:12(-62.39 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-71,“distance”:3.860897,“servicedata”:“080ca05252342d580104ed001002020164”}
09.09.2020 20:27:04(-67.95 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“080ca05252342d580104ee001102020164”}
09.09.2020 20:24:53(-2.18 minutes)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-74,“distance”:5.270232,“servicedata”:“080ca05252342d580104ed001202020164”}
09.09.2020 20:23:47(-66 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-76,“distance”:6.44788,“servicedata”:“080ca05252342d580104ed001202020164”}
09.09.2020 20:22:41(-66.42 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“080ca05252342d580104ed001302020164”}
09.09.2020 20:21:39(-61.96 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-74,“distance”:5.270232,“servicedata”:“080ca05252342d580104ed001302020164”}
09.09.2020 20:20:29(-69.84 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“30587605cba05252342d5808”}
09.09.2020 20:19:23(-65.4 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“30587605c9a05252342d5808”}
09.09.2020 20:18:17(-66.08 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“30587605c7a05252342d5808”}
09.09.2020 20:17:20(-56.82 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“30587605c5a05252342d5808”}
09.09.2020 20:16:05(-75 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-73,“distance”:4.756481,“servicedata”:“30587605c3a05252342d5808”}
09.09.2020 20:15:01(-64.49 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-73,“distance”:4.756481,“servicedata”:“30587605c1a05252342d5808”}
09.09.2020 20:13:54(-66.74 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-74,“distance”:5.270232,“servicedata”:“080ca05252342d580104ec001302020164”}
09.09.2020 20:12:50(-64.06 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“58587605bca05252342d58ef42ab35914900001e7c4f44”}
09.09.2020 20:11:44(-66.11 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-74,“distance”:5.270232,“servicedata”:“30587605b9a05252342d5808”}
09.09.2020 20:10:37(-67.18 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-72,“distance”:4.287841,“servicedata”:“080ca05252342d580104ec001302020164”}
09.09.2020 20:09:33(-64.09 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“080ca05252342d580104ec001402020164”}
09.09.2020 20:08:25(-67.67 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“30587605b3a05252342d5808”}
09.09.2020 20:07:22(-62.9 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-72,“distance”:4.287841,“servicedata”:“080ca05252342d580104ec001502020164”}
09.09.2020 20:05:08(-2.24 minutes)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-74,“distance”:5.270232,“servicedata”:“30587605ada05252342d5808”}
09.09.2020 20:04:04(-64.31 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-62,“distance”:1.429824,“servicedata”:“30587605aba05252342d5808”}
09.09.2020 20:02:57(-66.57 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-61,“distance”:1.274439,“servicedata”:“30587605a9a05252342d5808”}
09.09.2020 20:01:51(-66.12 seconds)
{“id”:“58:2D:34:52:52:A0”,“name”:“Qingping Alarm Clock”,“rssi”:-61,“distance”:1.274439,“servicedata”:“30587605a7a05252342d5808”}
HI there,
Thanks a lot for your great work!
I just wanted to make a note for someone that maybe faced or will face a problem connecting CGD1 to Open MQTT Gateway. Mine was appearing in MQTT Explorer but without temperature and humidity values, just “servicedata”:“080c3ae452342d580104e1008101020164” or “servicedata”:""
I added code “|| strstr(service_data, “080c3a”) != NULL)” to line 997 in ZgatewayBT.ino and now I get
“name”:“Qingping Alarm Clock”,“rssi”:-59,“distance”:1.01076,“model”:“CGD1”,“tem”:23.5,“tempc”:23.5,“tempf”:74.3,“hum”:36.6}
“080c3a” is a substring of first 6 characters from servicedata “080c3ae452342d580104e1008101020164” that I saw in serial logs without code modification.
I think that this “servicedata” can be diferent for some lots of deviced. I’m not sure if it is, but maybe it will help someone.
Thanks for the info, I think we should change this filter, maybe taking into account the device name instead of a servicedata criteria
