A piece of the serial log showing that mqtt-subscription and decoding of RF seems to work:
"mqtt_server":"192.168.x.x","mqtt_port":"1883","mqtt_user":"rfgateway","mqtt_pass":"xxxx","mqtt_topic":"home/","gateway_name":"RF-Gateway"}N: RF_EMITTER_GPIO: 5
N: RF_RECEIVER_GPIO: 4
N: Setup OpenMQTTGateway end
W: MQTT connection...
N: Connected to broker
N: Subject: /SYStoMQTT
N: Received json : {"uptime":3,"version":"version_tag","freemem":40744,"rssi":-60,"SSID":"ssid","ip":"192.168.y.x","mac":"2C:F4:xx:xx:xx:xx","wifiprt":0,"modules":"RF"}
{"mqtt_server":"192.168.x.x","mqtt_port":"1883","mqtt_user":"rfgateway","mqtt_pass":"xxxx","mqtt_topic":"home/","gateway_name":"RF-Gateway"}N: RF_EMITTER_GPIO: 5
N: Received json : {"uptime":7,"version":"version_tag","freemem":40744,"rssi":-61,"SSID":"ssid","ip":"192.168.y.x","mac":"2C:F4:xx:xx:xx:xx","wifiprt":0,"modules":"RF"}
N: Received json : {"value":4280657,"protocol":1,"length":24,"delay":307}
N: Received json : {"value":4280660,"protocol":1,"length":24,"delay":308}
N: Received json : {"value":4280671,"protocol":1,"length":24,"delay":308}
N: Received json : {"cmd":"restart"}
N: Command: restart�
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
load 0x4010f000, len 1392, room 16
tail 0
chksum 0xd0
csum 0xd0
v3d128e5c
~ld
N:�{"mqtt_server":"192.168.x.x","mqtt_port":"1883","mqtt_user":"rfgateway","mqtt_pass":"xxxx","mqtt_topic":"home/","gateway_name":"RF-Gateway"}*WM: [3] allocating params bytes0
N: Received json : {"uptime":3,"version":"version_tag","freemem":40744,"rssi":-58,"SSID":"ssid","ip":"192.168.y.x","mac":"2C:F4:xx:xx:xx:xx","wifiprt":0,"modules":"RF"}
