WT32-ETH01 and CC1101 wirring
Hi all,
I’d like to change from my custom rpi RF solution to openmqttgateway. I’ve ordered an WT32-ET01 and a CC1101. But the wiring instruction for esp32 does not match.
Have anybody use an WT32 with CC1101?
Here the documentation of WT32:
http://www.wireless-tag.com/wp-content/uploads/2022/10/WT32-ETH01_datasheet_V1.3-en.pdf
Thank you in advance!
hi
[env:esp32dev-multi_receiver-eth01]
board = esp32-gateway
;board = wt32-eth01
  ${libraries.wifimanager32}
  ${libraries.rc-switch}
  ${libraries.rtl_433_ESP}
  ${libraries.esppilight}
  ${libraries.newremoteswitch}
  '-DESP32_ETHERNET=true'
  '-DETH_PHY_ADDR=1'
  '-DETH_PHY_POWER=16'
  '-DETH_CLK_MODE=ETH_CLOCK_GPIO0_IN'
  '-DZgatewayRF="RF"'
  '-DZgatewayRF2="RF2"'
  '-DZgatewayRTL_433="RTL_433"'
  '-DZgatewayPilight="Pilight"'
  '-DZradioCC1101="CC1101"'
  '-DvalueAsATopic=true'  ; MQTT topic includes model and device (rtl_433) or protocol and id (RF and PiLight)
  '-DDEFAULT_RECEIVER=2'  ; Default receiver to enable on startup
; *** RF Module Options ***
  '-DMQTT_USER="***"'
  '-DMQTT_PASS="***"'
  '-DMQTT_SERVER="192.168.1.17"'
  '-DMQTT_PORT="1883"'
  '-DRF_CC1101="CC1101"'  ; CC1101 Transceiver Module
  '-DRF_MODULE_CS=2'      ; pin to be used as chip select
  '-DRF_MODULE_GDO0=4'   ; CC1101 pin GDO0
  '-DRF_MODULE_GDO2=17'   ; CC1101 pin GDO2
  ;'-DRADIOLIB_DEBUG=true'
  ;'-DRADIOLIB_VERBOSE=true'
  ;'-DRF_MODULE_INIT_STATUS=true'    ; Display transceiver config during startup
 ;SCK_PIN = 12; MISO_PIN =15 ; MOSI_PIN =14 ; SS_PIN = 2;
define in config_RF.h
     define RF_RECEIVER_GPIO 17
     define RF_EMITTER_GPIO 4
define in ELECHOUSE_CC1101_SRC_DRV.cpp
      #elif ESP32
enjoy it works…
Hi Alexsys81!
Your Solution looks great. however, i do not have “ELECHOUSE_CC1101_SRC_DRV.cpp” in my project.
can you help me where i finde the proper place to chance the MISO/MOSI Pins.
Thanks in advance Christoph
Dear, @Christoph_Pramhofer ,
did you get it working at the end with the suggestion of @alexsys81 ?
So to get it working do you have to build from source?
Hello, I did it the same way, but I cannot get it working. After typing in wireless connection info I get looping. I commented out epspilight and dzgatepilight, because they seemed to conflict with rtl_433.
In the log I get this:
[   137][E][Preferences.cpp:47] begin(): nvs_open failed: NOT_FOUND
N: SYS config not found
N: OpenMQTTGateway Version: edge
N: OTA server cert hash: 02118cbaf5cc02748398d93ecdb0ef2a444c37358a617bfb2206dfe351dc7cf2
N: Config loaded from flash
N: Spl eth cfg
N: Ethernet Connected
N: Ethernet started
N: .
N: .
N: .
N: .
N: .
N: .
[  8412][E][Preferences.cpp:47] begin(): nvs_open failed: NOT_FOUND
N:
N: Spl eth cfg
N: Ethernet started
N: .
N: .
N: .
N: .
N: .
N: .
[  8296][E][Preferences.cpp:47] begin(): nvs_open failed: NOT_FOUND
N:
This everytime repeats. What can I do fixing this?
Maybe @1technophile can help here :slight_smile:
