433Mhz DIGOO NEW DOOR & WINDOW Sensor versus Golden Security GS-WDS07 comparison
We have currently 2 competitives window & door sensors that sit on the top of autonomy measurement:
Affiliated link
Affiliated link
So as to make an advised choice here is a detailled comparison:
Characteristics GS-WDS07 NEW DIGOO
Range >25m ~13m
Autonomy ~2y >5y
Battery type AAA Lithium CR2450
Signal Open yes yes
Signal close yes yes
Signal tamper depend yes
Signal low battery yes yes(not verified)
Size compact normal
Signal led yes yes
Compatibility RF, Pilight RF
In synthesis the main criterias that differentiate both sensors are the autonomy and the range, in terms of range the GS-WDS07 is a lot more powerfull compared to the DIGOO. At the opposite it results in an impressive autonomy for the DIGOO.
Your choice will depend to the distance between your windows/doors and the gateway, if you live on a small flat for example you will not need the power of the GS-WDS07 and could take the DIGOO.
For a house or a big appartment I will advise the GS-WDS07.
It work but when open door don’t close is throw error
I use BLE ESP32 NodeMCU LuaNode32 30 pin
Guru Meditation Error: Core  1 panic'ed (Cache disabled but cached memory region accessed)
Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x401f4d90: bad00bad bad00bad bad00bad
Guru Meditation Error: Core  1 panic'ed (IllegalGuru Meditation Error: Core  1 panic'ed (Unhandled debug exception)
Debug exception reason: Stack canary watchpoint triggered (%)
Guru Meditation Error: Core  1 panic'ed (Guru Meditation Error: Core  1 panic'ed (Guru Meditation Error: Core  1 panic'ed (Guru Meditation Error: Core  1 panic'ed (Guru Meditation Error: Core  1 panic'ed (Guru Meditation Error: Core  1 panic'ed (Guru Meditation Error: Core  1 panic'ed (Guru Meditation Error: Core  1 panic'ed (Guru Meditation Error: Core  1 panic'ed (Unknown reason)
Debug exception reason: BREAK instr �@␐␂�?ailed: esp_e�@6
Sorry but I don’t know what to do with these logs that are not comming from OMG
Thank’s for this comparising. Two questions: What does tamper ‘depend’ for the wds07 mean?
And for the sizes. From the picture they look more or less the same. Is the wds really smaller and if so why? Is it the thickness?
Thanks again! :slight_smile:
Sometimes they are delivered with a tamper switch; sometimes not :frowning:
The digoo is smaller in heigth and looks more compact.
