[Buy Advice] Digoo DG-HOSA Door Sensor
Hi Guys, i’m starting to learn just now.
This Digoo sensor is really cheap, does it integrates with OMG? I don’t know if its a older version of the rounded one.
Digoo DG HOSA hosa sem fio proteger janelas portas sensor para 433mhz sistema de alarme detector segurança em casa kits|sensor sensor|sensor for alarmsensor wireless - AliExpress
I want open/close codes to integrate it into Homebridge. Do you guys recommend other options for this setup?
Hi!
Here are the 2 433mhz sensors that I recommend with their PROS/CONS
Thank you, i’ll go with those.
BTW, researching on Aliexpress costumer replies it don’t seen to have open/close different codes.
